AG carries the HD Foam BP by Flex. The foam helps when buffing across contoured panels. If you want the very best in backing plates, try the 3M Perfect-It. Pricey but worth the extra.
I also was interested in that Flex rotary BP.... apparently it's only for Euro-spec buffers and is an M14 fitment. Not 5/8 so you need an adaptor to make it work (if you can even locate a place to buy one of these).
