Flex PE 14-1 180
I was browsing the German Flex website and came accross this Rotory. Identical to the PE 14 2 150 from AG but this one operates from 250-1350...
FLEX-Elektrowerkzeuge seit 1922#
I like this attribute:
•Polishes at extremely low revolutions and high torque,
e.g. for heat-sensitive surfaces
And...Thanks for sharing this info Mike!!
No problem gentlemen. Thought I would share my findings.
I think this would be better suited to us detailers with the lower speed and ability to jewel the paint. But how effective would jeweling be if its only spining 250 rpm?
I see it has a M14 spindle thread,so it's probley also running 230v.Hope they import these and incorp a 5/8-11 and be phased 110v.
Good question Mike!!
It would be very interesting to see how rotaries may be used
to jewel at speeds of ~250-500 rpms. Because:
The way I used to Jewel when the lowest speed on any of my rotaries was: ~ 800-1000 rpms.
(Don't jewel much anymore---gave my rotaries to family members for use on their boat/RV):
At first...To start breaking-down the polish's abrasives:
-High speed ~ 1500-1800...
-Firm downward pressure...
-Arm speed: polish dependent...though usually "moderately slow"
Secondly...As the polish starts to go 'clear':
-Speed reduced to ~1200rpms...
-Reduce downward pressure (moderate)
-Reduced arm speed
Lastly, and...When the polish's abrasives have been completely broken-down:
-Reduced speed to ~800-1000 rpms...
-No downward pressure...
-Slow arm speed for a few passes
And, besides the above 'jeweling-factors', there are some others to consider:
1. Selection of the polish (and its abrasives...usually diminishing)
2. Pad choice/keeping the pad 'clean'
3. Not polishing long enough to completely break-down the abrasives
4. Polishing too long...allowing all the polish-lubricants to evaporate
Sorry for the rambling...
Now...Back to your question...
-Won't know if jeweling ~250 rpms, or so, can actually be accomplished without:
1. Personally having one of these particular Flex Polishers for a "try-out"
2. Having someone else to purchase one for their "try-out";
and, then, piggy-backing off their experience.
On the other hand (if jeweling was not feasible at such low speeds/rpms)...I suppose:
-I would use the lower speeds/rpms for a: "Soft-start", as it were.
Hopefully we can get this in the U.S. from AG IID...
Bob that is incredible information. You never fail to impress me my friend.
I consider 3M Ultrafina a jeweling polish and 3M recommends 1800 rpm, so 250rpm Dunno.
Flex makes a bunch of polishers. I think they all have soft start. For a rotary I wouldn't want to be restricted to 1350 rpms. The PE 14 goes to something like 400 rpms on the trigger. Like others have said I'm not sure 250rpms is all that valuable.
All very good points and I wanted to share my findings with my fellow geeks on a new machine.
Absolutely much appreciated. This one has merit. Can't understand why Flex makes 3-4 modules so close to each other. One of their models looks like a PC on steroids. So far I've been impressed with their tools. Just wish the we're priced about 25% less expensive.
Wow, a Flex DA! Only if this was made to our specs.
In action....
[ame=http://www.youtube.com/watch?v=dUDRzMXsTtU]Flex X 1107 VE Orbital Sander - YouTube[/video]
:iagree:
I would like to get my hands on one, if for no other reason just to put it through it's paces.
