Flex PE14-2-150 speed dial problem
mxfly
My Flex rotary seems to be stuck in the fastest setting. I've tried dismantling and cleaning the guts. No luck. Someone suggested the carbon brushes needs replacement but before i commit to buying them, has anyone had the same problem?
thanks.
if you can't get it fixed, try calling (google) powerhouse distributing in Omaha, NE. they've been an authorized flex repair facility/center since the beginning...
Unfortunately I'm not in the States so cant send it there.
Probably the electronic module is busted.
Try to contact them, buy the part, and fix it in your country.
Is it 110v or 230v?
It is not gonna be easy to find this part, since the 110v module won't work on the 230v.
Therefore, forget about finding it in US.
Try to contact Flex Germany directly, and explain your problem.
If the polisher is 230V 50hz, and your power grid runs on 60hz, avoid running on max speed, never go more than 5.
Best regards
Sorry my mistake. Mine is a 110V unit and I use a step down transformer here in Aus. Can you pls recommend a place in the US to purchase an electronic module?
thanks heaps
Please do not do anything other than buy a FLEX machine that's designated for your country. Using a transformer to bring the power down so you can use your machine will kill the speed module every time.
I too was in the same boat as you. I have U.S. spec machines and currently live in Germany where 230v is used. Before I did anything with the machine I sent an email over to FLEX about my situation. They responded against using a transformer with the machine as it will take out the speed control. The best course of action is to use a machine from my market as it is designed to work with the power supply that we have here.
Luckily for me I have access to both 110v and 220v and can use the proper power supply for my machines without issue.
Just sharing my situation so you have a heads up.
Thanks for the info.
I purchased the machine before it was available in my country. Took the advice from someone here of using a step down transformer and since then, had absolutely no issues with it until just recently, about 2 months ago. All these years it worked fine but I wasn't aware that Flex did not recommend it.
The unit costs over 600 bucks here and although I did consider buying a new one, all my backing plates are in imperial which would not be suited for the machine sold here which are in metric.
I'm willing to purchase another 110v module just to get me going again.
cheers
Just to chime in...
I've spoken to Bob Eichelberg about this issue in the past and he states the exact thing Mike said and the problem starts with the host country's electrical system.
Fixing your PE14 and then using it with the step down transformer will just lead to the tool malfunctioning again.
If you like the compact size, RPM range, fit and finish of the FLEX PE14 and plan on doing buffing work with a rotary buffer for the long run the the best solution would be to purchase a FLEX PE14 built for and sold in your country.
Not sure if that helps but that is the reality of the deal.
Just to chime in...
That's exactly where I got my information from. The man himself Bob Eichelberg. Not only from him but others at FLEX while there in person.
http://www.autogeekonline.net/forum/flex-polishers/78281-smack-tours-flex-tools-gmbh-germany.html
I Wanted to share with the OP my situation so he had an idea of what he is doing.
I also agree the best course of action would be to buy the machine from his market. Using the transformer will take out the speed control. Its just a matter of when the speed control kicks the bucket when used in this method.
