These are really different classes of machines. The PXE is cordless and can be operated as a rotary, or DA with 3mm or 12mm orbit (or 6mm if you buy a separate attachment). The XFE 3" operates only in 12mm DA mode, but as a larger, corded tool, is going to be a lot more powerful.
Well, the G13 is kind of in the class of the XFE 3", so the Griot's analog to the PXE 80 is the Boss Hybrid Micro Polisher.
The only feedback I can give you is I not too long ago bought an SPTA Cordless Mini Polisher, which is kind of the same idea as PXE 80 and Boss Hybrid, and I was underwhelmed by it.
If it's between the G13 and the XFE 3", I'd go with the Griot's all the way, simply due to the trigger vs. switch.
It really depends what you want to do, I have an old GG 3", and an old PC I use for 4" pads, so for me I wanted something for 1" and 2" pads, but the little mini machines don't have the power of the larger-frame corded machines, it's kind of borderline using them with 3" pads, at least that's my take with not much time behind the wheel of my SPTA mini.
Yea I've been using the GG6 for 4" pads. Well...maybe I'll just stick to the tried and true G8. It's relatively cheap and can do anything from 1"-3" pads.
A rotary polisher with a 1 or 2 inch pad is a recipe for disasterI felt in DA mode in my very limited use the PXR was kinda weak. Fine in rotary mode but didn’t really want a 3” rotary. I use it with 2” and 1” pads.
Ultimately if polishing a lot I would recommend both.
Why is that, Flash? It's not a recipe like a rotary with a 9" padA rotary polisher with a 1 or 2 inch pad is a recipe for disaster
The Flex PXE has comparable power compared to the G13
Sometimes I feel like speed 3 isn't enough but 4 can be a bit of overkill. I wish there was a happy medium between those two power levels.Wow. I'm going to have to fool around with my SPTA mini some more...but maybe you really do get what you pay for.
Not that i have ever known. Would be handy.Does Flex make a 1-3" forced rotation corded polisher? I have the GG3 that's a rotary and I don't like it one bit.
