Why does the Flex da have more correction power than the PC?
The flex isn't a da, it only orbits. It is an orbital.Why does the Flex da have more correction power than the PC?
You are correct, sorry. I spoke to a flex rep who also used to work for porter cable. When he was describing the differences I mis-understood him as saying the flex was not a da, while their website says otherwise.Please notice in detailing forums "Flex" is a synonym for Flex XC 3401 VRG, which _is_ a DA.
Many enthusiasts refer to the Porter Cable 7424 as a D-A or dual-action polisher. It isn't. The 7424 is an orbital polisher. This Flex XC3401VRG is a true dual-action machine. There's a huge difference between the two. With the Porter Cable 7424, the pads do not rotate, they oscillate, or jiggle, in a random pattern designed to simulate hand application.
now im more confused....
so with a PC if you push hard enough the pad stops rotating....
with a flex it does not? (forced rotation?)
does the flex still rotate AND oscillate? describe the action for me.Feed back please
Dual Action (DA)- Spins in a random orbit motion, and rotationally...
The PC/G110/UDM are considered DA's, as the do have both motions, just like the FLEX 3401. The main difference is that the FLEX is forced rotational polisher, where the PC/G110/UDM have less powerful motors, and they have a safty cluth in them, which will stop it from spinning rotationally when too much pressure is applied. One can argue that the PC/G110/UDM are not a true DA's, but when used correctly they are in my book.
Rasky
so the flex orbits and rotates and its forced. correct? That would be a POWERFUL correcting tool! Im the MAN
Correct.
It is a great too and I love mine, but it's not quite as powerful as a rotary.![]()
