After ~7 years of use, my Porter Cable is starting to show signs of its age, and I'm ready for an upgrade. It doesn't always want to run at lower settings, but will still run at 5 & 6. After perusing the autogeek site, the FLEX XFE7-15 Long Stroke Orbital Polisher has caught my eye.
I fit into the "weekend warrior" (of 2-4x/year) between my car & boat. (I baby the boat, and it doesn't have oxidation issues requiring a rotary).
One thing I've learned over the years with the PC is that if the entire pad isn't on the surface, product gets flung all over the place --- creating a mess, which leads me to my question...
For cases of side-mirrors, and all the fancy paneling at the lower-front of the car, I find the 3-4" pads are easier to work with, then use 5-6.5" pads on the larger surfaces.
Can I put the "FLEX XFE 7-12 3 in. Backing Plate" on the "FLEX XFE7-15", or can the 3" plate only go on the XFE 7-12?
(As I'm not a professional detailer, nor do I have any desire to become one, dropping $379.99 on the FLEX XFE 7-12 isn't going to happen for the above mentioned edge cases --- but I'd be willing to spring for plates/pads)
If I can't put the 3" plate on the FLEX XFE7-15, is my best bet to pickup another PC for the 3.5-4" pad use cases?
Thanks for any guidance of the use of plates on different polishers!
Michael
PS. I'd also plan on getting the FLEX XFE7-15 5 inch Backing Plate as I have a nice collection of 5.5" LC pads that I've used with my PC & don't want to see them go to waste.
Michael
