Flyby application question
bill buxton
I have just started using Carpro Flyby 360 and have cleaned the glass and applied the product no worries. My question is, can you apply and walk away, or do you let it flash and wipe with mf?
Also can you layer the product with multiple coats after a short wait? I used the suede applicator and straight app block when treating the glass with a few drops and many directions one coat. I then after one coat let it dry 5-6 hrs.
Any info on the above fellas....
Thanks Much...
I work FlyBy30 the same way i apply coatings to paint. I also clean the crap out of the glass before. I work it in using 2 passes...one left to right and another up and down. I do 4 seperate application sections on a typical windshield. after each section is applied I wait anywhere from 20 seconds to a minute and then work it lightly with a plush MF towel carefully looking for any high spots and working them till gone.
I have also applied a second layer the same way. sometimes I do another layer immediately and sometimes I do another layer at the next weekly wash.
I have learned to make sure I level and remove any streaking or high spots after leaving a few the first time I tried it. It's tough to see those on glass during application but my worklight placed at the right spots outside help.
