Foam cannon for Homelite pressure washer?
michael13
Member
I have been looking into picking up a pressure washer, and have been looking for a foam cannon to use with it. Budget is up to $400 for the pressure washer, and up to $150 for the foam cannon.
I found a Honda powered Homelite 2700psi pressure washer at Home Depot, and would like to know if there is a Foam Cannon available that will work with it.
Homelite 2700 psi 2.3 GPM Honda Gas Pressure Washer-UT80993A at The Home Depot
Suggestions for other gas powered pressure washers within my price range --up to $400, would also be appreciated.
150 for a foam cannon? u can get a mtm hydro foam cannon for $60 , lots of us use this . it will come with the male end to hook right up to the quick connect fittings on your pressure washer .
I would prefer to not spend the absolute max, however, I stated the absolute max I can spend on each item.
I would rather have an electric pressure washer.
But any pressure washer with a quick connect tip should fit the mtm foam cannon. The one you have linked will work with the $60 foam cannon the majority of us use here.
If I had to go gas the main thing I would look at is the engine and I would make sure it is either a Honda or Briggs & Stratton. Other than that I would make sure the wand is metal, has brass fittings, solid construction, hose isn't flimsy.
I don;t have any recommendations on gas one's besides the things I would look for but if you want to go electric I wrote a review on one I just purchased.
