Foam Cannon HP Foaming Lance for your Pressure Washer
Dwayne
Turn a pressure washer into a high powered foamer!
Cover your vehicle in a flurry of foam quickly with the Foam Cannon HP! This foam lance works with a pressure washer to produce a thick, clinging foam. Give your vehicle a "touch-free" wash with this high powered foam gun. The Foam Cannon HP will blow you away!
The benefit of using a foam gun to deliver the soap to the vehicle is that it doesn't require you to touch the vehicle, which could rub dirt against the paint. The Foam Cannon HP sprays the vehicle with a thick coat of soap to loosen and lubricate dirt. On dusty or lightly dirty vehicles, you may not even need to hand-wash. The Foam Cannon HP minimizes the amount of hands-on contact with the vehicle, which can minimize wash-induced swirls. Plus, the Foam Cannon HP is a blast!
Take your pick, we have Foam Cannon HP's with your choice of Autogeek, Pinnacle or Wolfgang logo and 6 different connectors to choose from.
Autogeek Foam Cannon HP Kit with Free Bonus
Pinnacle Foam Cannon HP Kit with Free Bonus
Wolfgang Foam Cannon HP Kit with Free Bonus
DP Xtreme Foam Formula and a Foam Cannon HP!!!
My car looks just like that if parked outside in January! What's the big deal?:D
Frosting on a cake. Very impressive foam coating.
This is good news. I've been looking for a place that sells foam cannons. Most support the Karcher pressure washers. It's good to see there are options for folks that don't have a Karcher.
What fitting do I need for a Campbell Hausfeld? It looks like the Kew/Alto.
I want it to look like this:
That should be it but if you can post a picture of your current connector I can confirm it for you. We want to make sure that you get the right one for your pressure washer.
I too have a Campbell Hausfeld but it is a very old model that is most likely discontinued. The fitting I would need is the Lavor. Make sure you double check or post a picture so we can verify.
Maybe you can post a close up picture of the foam cannon's fitting so we can see what that looks like .I have a sears pressure washer the front wand unscrews from the middle so would i screw the foam cannon to the section that is still connected to the handle .I'm sure there is going to be alot of questions about hooking up foam cannons now.Or should just post pictures with our questions ?? Thanks Dwayne
The foam cannon has 1/4" female threads so you could go directly to the cannon without a connector if your wand has 1/4" male threads. Otherwise, you will need a fitting to make the connection.
Best bet is to show a picture of the piece that you are removing and also the fitting that you need to connect to and it will be easy to determine which connector that you need.
All I can say is Autogeek rocks !!!!!! I wish you would have gotten these sooner as I already Have 3 units. Are you guys going to make the Bottles and the fittings available seperately? That would be great.Maybe even sell a pressure washer and Foam cannon package !!!!!
Great ideas! :goodpost:
This cannon is awesome we played with it today, makes washing cars not only fun but fast!
I have a craftsman 1800 psi 1.6 gpm electric pressure washer and it has M22 fittings on it. I have the LS-3 foam cannon. Bought mine before Autogeek started selling them. The cannon has a brass 1/4" female fitting on it. My gun has an M22 female fitting on it. I used an M22 to 1/4" brass reducer coupling male on both ends to connect the cannon to my gun. I tried it this way but for the cannon to fit tight to the gun the bottle was sideways. I kept the reducer coupling on the cannon. I went to home depot and got a quick disconnect set up for it and my existing wands, M22 x 3/8" male socket to connect to my gun. M22 x 3/8" female twist on plugs for the cannon and my existing wands. That was all I needed. The foam cannons are awesome.
rwisejr is right, an extra bottle and lid would be a great add on item for most of us.
