Foam cannon soap ratio...
Bobbykart
Haven't used my foam cannon for a few years, got a new pressure washer and have ordered the new adaptor. I have some left over melon shampoo, but forgot exactly how to mix. Any input? BTW, gonna try some Car Pro quartz on.my daily driver to see if I like it
It's usually a couple of ounces but honestly it's more user preference. The more you add the foamier it will be. Some might argue it's not necessary or very effective and others, myself included, think it helps some for some pre wash techniques and most of all.... It's just fun...
Sent from my SM-G935V using Autogeekonline mobile app
I don't use the snow foams but for something like hyper wash I fill to the second line of my foam cannon
2-3 ounces of soap and the rest of the bottle with warm water...
With Gyeon Foam, 1:10 outta a PFM22 cannon and SunJoe SPX3001 works well, sometimes up to 1:15. Not the drier shaving cream foam, but a more aqueous foam that clings just long enough to meet recommended dwell time. Beneficial? I dunno but it's entertaining and easily done in short period of time.
With hyperwash I use 2 oz to get a good foam without wasting too much product.
what is the recommended dwell time?
What nozzle do you run on that setup...thats on my list
Sent from my SM-G930V using Tapatalk
Generally around 4-5 minutes max; sometimes a little less as foam sliding off coated surfaces determines it's time is up. Somewhat controllable by mixture knob on PF22, usually a touch under max foam.
3.0 (1.76gpm @ 2100psi)
My next question is do you use the gun with a long wand or just the gun itself
2 ounces for me works well with most quality soaps. I use warm water when it’s cold out as the soap doesn’t fully dissolve.but here in Texas the heat will heat up the water
Depends on the soap but i usually add more then what they recommend. Try adding some uber or n914 too
