orngez
- Feb 21, 2007
- 772
- Thread starter
- #21
P1et said:Hey, can you hook this thing up to a regular hose? Or only pressure washers?
the way it is set up...only pressure washers...although i am sure the threaded end could be changed out to accept a hose connection...not sure where you could get one...a foam gun i think would still be a cheaper alternative....also i am sure the foam cannon needs a lot more pressure than what a hose can provide in order to produce foam correctly...
