Foam cannon
I know they say you get what you pay for.
I seen some foam cannon's for pressure washers at some different prices. they all pretty much look the same to me.
Do you think there is a difference between them? and if so what would it be. any input would be appreciated
Th only differences I could see is the use of teflon tape and quality of the plastic and metals. I would go with one that has good supporting reviews as long as the price is not too far out there.
IMO...(regardless of the Brand/Manufacturer):
It's a good idea to coordinate the foam
cannon's GPM and PSI ratings/specs...
with those of the actual pressure washer
that's going to be used. Safety First!
MTM makes a good foam cannon. I suspect MANY other foam cannons sold are re-branded MTM products.
