Foam gun leaking???
MONSTERMATT
Does your foam gun leak ?? I just pulled mine out from storage and not only were the brass fittings all green and almost corroded the fitting by the rubber gasket seems to be leaking?? And just to refresh my memory, pour the suds in the container and let her rip??? Does yours leak??
no leaks ... sounds like you might have put it away wet ??? I would wipe it down well, and retighten as possible. I place water in first , then suds or it foams up and soap/water ratio is effected.
