SVTContour
- Mar 17, 2006
- 168
I just used my quart size foam gun for the first time on Friday. At first I added the entire 2 oz. sample of DP Xtreme Foam soap and 8 oz. of water like the directions say. The 8 ounces of water didn't even fill the container up half way, but I figured I would proceed. So, I set the ratio adjuster to the maximum (far right) and let it rip! The contents in the container only lasted 2 minutes MAX! and I was a little disappointed.
Next, I decided I would try it out again. So, I added about 2 ounces of Poorboy's Super Slick & Sunds, but this time I filled the container up about 90% of the way with water. I also, set the ratio adjuster back 2 spots. This time it worked much better, and I was able to do a pre-soak on my car and also lead my sheepskin mit while washing my car for the entire wash process.
I am just a little baffled why when I followed the directions on the DP soap it only lasted for two minutes? Was I not suppose to set it to the most concentratred dillution ratio?
Does anybody have any tips or suggestions for me being new at the Foam Gun? Thanks.
