I have a different version that has a spin dial.It worked nicely and foamed up great.So my mixture should b more water then soap then?add soap after filling with water first or you'll have alot of foam in canister. Shake or swish abit. Then use the foam setting (long brass pin with holes) to adjust the amount used and foam.
