hellzdragon
- Aug 3, 2010
- 6
First time use of the G110v2 today. The wash, clay, and polish (UC) all went fine. But when I started applying NXT v1, I noticed the SOFTBUFF FINISHING PAD (W9006 6.5 in.) absorbed a lot of wax.
The car was in the shade cool about 60 degrees, no wind, perfect detailing conditions. I had the DA set to speed 2 then 3. Started with a little extra NXT to get the pad started. Then used X and O shape beads on the pad. Light down force, faster hand movement, and double the polishing work space. When I was done with the hood and roof I can tell the pad was absorbing a lot wax. It was starting to prevent the pad from rotating. I had let the DA glide (little to no down force) over the surface so the pad would still spin. In some areas it looks like the foam pad picked up all the wax I applied.
I still finished the job but I felt I used a lot more wax than I normally do.
When I took the pad off, I can feel it was a lot heavier and a bit saturated in the center. Now when I apply wax I don't clean the pads like I do when I'm polishing. Although this is my first use of a DA, I've been a long time orbital user with bonnets. So what is causing the pad to soak up so much wax? Is it my technique or the pad?
