Foamaster's connection...?
Bernard
Hi there. Do you all think that I can use the green male connector onto the Foamaster's sprayer...? Those are standard garden hose connectors that I bought from the hardware shops. Thks. :)
Thats what I use. I HIGHLY reccomend the quick connect/disconnect that AG sells to place between the hose handle and the gun resevoir.
:iagree:. I use the garden hose quick connects for everything I hook to the hose and high pressure quick connects for all of my pressure washer stuff. Just carry a female fitting to put on different hoses. Never seen a plastic one like you've got in the pic.
I myself use Quick dis-connector, but the brass one's. Got them at the lowes and home depot.
autogeek_1976_11711664
Brass Quick Connector Set
Is this the one...? TQ. :)
The reason I asked was coz firstly I wasn't sure and 2nd we only got this plastics ones in our shops. But if this brass one is the one, then when I order the Foamaster. I'll order them together at once.... TQ. :)
I'd recommend getting the brass connectors. You'll never have to think abbout connectors again because they work so well. I beat the heck out of mine last summer and never had a problem with them.
Thank you all.... Grateful for your help. I'll get the brass connectors together wt the Foamaster. TQ. :)
