Tested the pads yesterday for the first time with no previous experience with this or other wool like pads. I can tell ya it's different to foam pads, which made me a bit
Which one of your Flex tools are you using it with?
The cut was amazing even if compared with most aggressive foam pads; I was shocked with it's ability but at the same time not sure as to how much product to use.
You'll notice your product tends to dissipate or disappear as you're buffing with these types of pads on the Flex 3401, not sure what causes this characteristic but do make sure you have "ample" product on the surface whenever you're buffing.
From this article,
How much product do I use with my DA Polisher?
Use an "ample" amount of product
When I say use an
ample amount of product this means don’t use too much product and don’t use to little product.
From The Free Dictionary.com
am·ple
adjective
1. Of large or great size, amount, extent, or capacity: an ample living room.
2.
a. Large in degree, kind, or quantity: an ample reward.
b. More than enough: ample evidence.
3. Fully sufficient to meet a need or purpose: had ample food for the party.
Out of the above definitions, I'm using the 3rd definition.
Using too much product
If you use too much you can hyper-lubricate the surface and this will make it more difficult for the abrasives to abrade the surface as they’ll tend to want to glide or slip over the surface instead of bite into the surface.
Using too little product
If you use too little product there won’t be enough lubrication to enable the buffing pad to rotate and thus engage the abrasives against the surface so they can bite into and remove small particles of paint.
You want an AMPLE amount of product when first starting out because you pad is dry and some of the product is going to seep into the pad leaving less on the surface to LUBRICATE and ABRADE the paint.
Obviously no need to prime, but really which is the correct way to work with this type of pad?!? How much product is needed?!? This is a completely a new ball game in detailing for me, so be easy please!
:dblthumb2:
With the Flex 3401, prime your pad with the product you're using then add some "working product" to the face of the pad, like dime sized dollops.
With a rotary buffer, use like you would any other wool pad, that is a strip of product about the size of a normal pencil for a 2 x 2' area and the spread the product out after picking up your bead and then work it.
I show that in this video with a wool pad but you can use the same tips and techniques with a PFW on a rotary...
Tips for using a Rotary Buffer and the Flex 3401 on vertical panels
[video=youtube_share;gc_umhlote4&hd=1"]Tips for using a Rotary Buffer and the Flex 3401 on vertical panels - YouTube[/video]
Anyone ever used the purple Foamed Wool Pads?
How to apply a compound such as M105? On the pad or directly on a panel? How about horizontal panels?
Thanks
See answers and video above...
