Folex & Bissell Pro
KyleWrap
Hello,
I have the Bissell Pro Spot Clean 3624. In the manual, it says to only use specific Bissell cleaning products. However, I love Folex ( as many people here do). Do you think i could use Folex with my Bissell Pro?
There aren't any instructions to dilute Folex on the bottle so I am not sure if I should dilute the Folex. With the Bissell its usually all water, and 2 oz's of the Bissell cleaning product.
Has anyone ever done this? Or can anyone provide any insight on this? Thanks!
Use Folex in a bottle and use the bissell with just water to extract
Thats what i figured. I wonder if the Folex would work better heated up if I were to use it in the Bissell
On the back of my 32oz bottle of Folex that I just bought a few weeks ago it says 'Using a machine with a mixing tank: mix 1 part FOLEX with 4 to 6 parts of warm water. (No defoamer necessary)'
I've only ever used it straight, I've not tried it in my Bissell.
This. I use this method for all carpet/upholstery cleaning. Only use the Bissell with hot water to extract/rinse after cleaning.
You can add Folex, I used to, but then you tend to use more Folex than you need to. It did work amazingly well.
