For a Beginner: Meguiar's G110v2 or Flex 3401
The Critic
Dear Mike and others,
I am trying to decide between these two units.
1) Meguiar's G110v2 with "soft buff 2.0" burgundy (cutting), yellow (polishing) and black (finishing) pads-- $190.
2) Flex 3401 with Yellow, Green, White and Blue CCS pads-- $310.
I am not going into the detailing business, so my work will be limited to my personal cars and maybe a few cars belonging to friends.
The Meguiars G110v2 is $120 cheaper than the Flex, which is a decent amount. I understand that these units have a very good resale value, so I'm sure I can resell either of these units for a good amount in the event I decide to upgrade. Furthermore, would it make sense for me to start out with a lower-end machine such as a G110v2 (as opposed to a Flex) if the next upgrade would be a rotary?
Also, remember that I am a beginner. I am also detailing daily drivers, not show cars, so the results do not need to be perfect.
Therefore, which machine should I get?
Thanks.
Thanks.
Depends on how many personal cars you own and how many friends you have. You will most likely polish a car once or twice a year with proper washing and drying techniques. If money is not a problem get the Flex. It will correct faster, but not necssarily better than the G110v2.
^ I agree if money is not an issue then get the flex. If it is then the Megs will do everything you want. I will say though the flex IMO has the capabilities to correct 85%-90% of what a rotary can so if you are just doing your cars there is no critical need to upgrade to a rotary.
Thanks for the advice.
Someone on autopia brought up a new idea that I had not considered and I would like your inputs on.
For the price of a Flex, I can purchase both a G110v2 and a Makita 9227C (with a LC 6" backing plate).
Wouldn't it make more sense for me to have both a G110v2 and a rotary? I would assume that once I master the G110v2, I would graduate to a rotary and the G110v2 would still come in handy.
What are your thoughts on this?
Doing the combo like you suggest is a good system, having a rotary and a DA polisher will enable you to tackle anything that comes your way.
Maybe we should start a "Tool of the Quarter" club and every quarter, (of the year), you add a different tool to your collection.
:buffing: :buffing: :buffing:
That's what I have, a DA and a rotary. I was in the same boat when I had to make a choice between the Flex DA or a rotary and a DA. Since you are doing only a few cars...the Flex DA would be a better choice for you. You don't have any experience with a rotary, so a Flex would be a better machine for you. You can alway's step up to a rotary if you need it in the future.
Have you read this yet?
How to choose the right polisher for your detailing project
Ron's right in that compared to a rotary buffer, both the DA style polishers, and the Flex 3401 are a lot easier to learn how to master.
I gave all the tools a "Ease of Use Ranking" in the above article.
Ease of Use Ranking
Each of the tools below are also graded as to their ease of use using a scale from 1 to 5, with 1 being the easiest and 5 being the most difficult.
Ease of Use Ranking
Yes, I have read that. Now that you bring the article up, this question has come to mind.
If I want to eventually move to a rotary, does it make more sense to train on and master a Flex 3401 or a DA such as the G110v2?
A rotary is a completly different animal. The Flex DA is closer to a rotary as it has forced rotation. I believe it only spins at 400 rpm which is not even close to a rotary. Most correction on a rotary will be 1200-1800 rpm. Using a DA or Flex DA will give you the feel of using a machine to polish. This will help you when and if you decide to step up to a rotary. I don't own a Flex DA, but most will tell you that it can do correction work pretty well. There are some that don't even use their rotaries anymore.
I agree with Rsurfer. I used the new Griots and the Flex 3401. Get the Flex if you have the money.
You don't do this for a business so I don't think you will want to or need to move to a rotary. The Flex is just a wonderfull and beautiful machine. http://www.autogeekonline.net/forum...lex-xc-3401-dual-action-orbital-polisher.html
Full disclosure: I have never used a rotary and I almost never say never but... I will probably never buy a rotary. LOVE the Flex 3401
