Desertnate
- Aug 5, 2013
- 6,239
- 294
In the process of bringing one of my cars "back to life" I've run across two decals that I cannot seem to get off the glass. I'm hoping folks here might be able to provide some suggestions. Here is what I'm up against.
Decal #1: Paper based manufacturer window decal on side window. It's fractured, rock hard, and I've only been successful in removing pieces of it. I've tried window cleaner, Goo Gone citrus based cleaner, and even a razor blade scraper with little to show for my efforts. Nothing appears to soften this sucker. Soaking the decal with the solvents/chemicals only partially softens the paper, but not enough to come lose.
Decal #2: Vinyl based parking sticker on rear window. I've tried the same chemical products as above and it only resulted in removing the paint/color from the decal, but I can't seem to get that vinyl base to come loose. I cannot use the scraper because it laps over the rear defroster wires and I don't want to run the risk of cutting/breaking those.
Any suggestions will be greatly appreciated.
