2) - Applying with a microfiber polishing cloth
Another method of applying a Meguiar's Spray wax is to apply it using a microfiber polishing cloth. Here's my daughter misting some NXT Tech Wax onto a clean, folded Ultimate Wipe. The trick to making this technique work is only using one side of your folded microfiber polishing cloth to apply the NXT Spray Wax over the entire car.
First she moistens one side of an Ultimate Wipe and then she can either spray some NXT Spray Wax onto the finish, or continue to spray some onto this same side of the Ultimate Wipe as she works her way around the Pilot.
The reason this method works is because once you have dampened one side with wax, you now have a wax-moistened surface that spreads and applies wax like the foam applicator pad. If you try to continually switch to a new, dry side, the cloth will tend to adsorb your product while your trying to spread it out and thus you will feel like you're fighting yourself while trying to spread the product out.
