I've read as much as I can find and I'm still not sure how to proceed. I've got a '63 vette roadster that I just resprayed with a dark blue metallic acrylic lacquer, 3 coats ss base then 3 coats of clear. It was done a week ago. No sanding was done between the coats so I do have a fair amount of orange peel to deal with. Two days after spraying I wet sanded several panels using 3M 1000grit wet on a spongy pad just to see how it would clean up. I didn't get too aggressive, maybe removing 80% of the peel on the panels. Looks OK. The car had been disassembled prior to the paint, then the doors, hood, deck lid and rear valence were temporarily reassembled for paint. I'll have everything off again, so I can work on most of the surfaces horizontally when I finish them. I also have a lift to raise the car to work on the side panels.
Here's my plan: finish wet sanding with the 1000 then repeat with 2000 and finally 3000, then use a Flex 3401 with M105 and on to M205. Then in a month or so seal or wax it.
I've got zero experience. I have none of the equipment but I'm willing to get whatever I need. From what I've read I don't think I want to attempt a rotary and I'm not sure a pc would be enough, therefore I'm thinking flex. Am I on the right track? Is lacquer soft enough to get by with a pc?
Any input is welcome
Thanks,
Ken
Thanks,
Ken
