Coopers ST
- Nov 23, 2013
- 1,268
Like the title says, should I get frosted or clear lense LED lights?
thanks
thanks
What will these lights be used for?
4 footers?
Feit makes ballast bypass LEDs to retro t8/t12 lights. They work great.
I got mine at Menards. They have a frosted lens
Yes 4 foot. Are they plug and play, or do you need to remove the ballast?
IMO, frosted. The clear ones you can actually see each LED reflect and it gets distracting when you’re trying to see defects on paint.
I completely agree, the matte light does not create glare that prevents you from seeing the real picture. On the contrary, it distributes the light evenly.Very true.
A frosted lens over the light source diffuses the light a bit and spreads the light more evenly across the surface to keep you from getting dazzled or distracted by the light source.
