trhland said:left my liquid wax out in the garage now its frozen. is it now ruined?? it says on the bottle keep from freezing.
trhland said:liquid carnuba spray wax from pro
Al-53 said:you should be ok...just when it warms up shake it up good..in case they separated some...the worse products to freeze are polishes and LSP sealants...some times they separate and will not re mix...they curdle and never re mix....I left a bottle of Mothers Top Coat in the garage last winter and it froze..come spring I seen it..opened it..was like cottage cheese....was toast..junk...
but shake the bottle up as soon as it warms up..should be fine....
Al
FloridaNative said:Okay. I confess that I wanted to know the answer to this question as well so I called Meguiar's for you.I spoke with Tim and he told me that he strongly recommends that you contact the company you bought it from because there is a risk of it "going bad" as he put it. He said it's not good that any of their products freeze.
Nica said:FloridaNative your quite the gall aren't you, very nice of you to make the call. I too worry about products freezing, so far everything I have ordered has arrived here extremely cold not frozen though. I was told by a pro autobody dealership that if you recieve anything frozen (specially compund products) to contact the place you got it from because most of the times they should not be freezing and if they do the chemical blend is now lost. Well at least that is all I remember.
All I remember frozen products is not a good thing.
Al-53 said:Alot of car care products state..do not let freeze or keep above a certain temp..reason being they can change chemically
There was a post on Detail City on this also..and Steve chimed in ..but i can not get the City to load today..I was going to copy what was said...
also a good practice...during the winter when your products are idle from not being used...pay them a visit and give them a shake up..to keep them in a mixed form...never hurts to do so...
Al
THANKS!!!CalgaryDetail said:I sure hope you havent thrown it away yet. It can be saved. (trust me i have alot of provducts freeze and very few have any ill effects). I would let it thaw and give it a good shaking (the wax will seperate like salade dressing). Just give it a good shanking to make sure it all mixed up and you will have no problems... i run into this problem alot. So dont worry
trhland said:i took the wax gave it a big hug told it i was sorry for letting it freeze then i put her next to the heater . now shes all better.![]()
trhland said:thanks guys . pro said it should be fine .i said to them that it says on the bottle keep from freezing . and they said that it says that manly so if it freezes really bad it could exspand the bottle and leak that s all. .its more for 5 gal containers not to freez because they really expand and could pop! so hopefully we should be ok.
the sprya wax looks fine to me this morning it didnt seperate at all. the dealer told me they do feeze tests are there products to check them and its fine . and it looks ok too didnt change color.Nica said:Really, this is interesting. Question though, how do you know it's bad? The pro said to you that it "should" be fine....so how do you know it's not fine? Does it change color? Is it more translucent? Just thought I'd ask because I was under the impression that freezing any liquid polish and wax was bad because it separates the chemicals and even though you can shake it the chemicals do not blend properly? Well like I said just asking.
