Al-53 said:Lucas works good...I buy it buy the gallon...I use it after I use a good cleaner like Techron or Seafoam or BG13....I use it in every 3rd fill up...or every 3 weeks...I fill up weekly.,,,
after reading alot of info the Lucas is a good after cleaning product to keep injectors clean and lubed...
also another good cleaner is the Syntech Injector cleaner....
AL
MTHall51 said:Thanks AL I am not sure who makes Syntech or is that the brand name?
You ever try JB line?
FMINUS said:I have always wondered about if fuel additives worked. How can you tell if it works? And I hope its not "It pulls harder"
killrwheels@autogeek said:BG44 ... the only noticable difference !
blk45 said:Also, if you only run Top Tier gasoline in your vehicle, it will greatly reduce the need for any other additives. Still a good idea to do from time to time though.
blivengood said:Scott, Where can I get this BG-44 and how often do you put it in your car?
Thanks
Bobby
killrwheels@autogeek said:I do it once a year, its some serious stuff. Its like a colonoscopy for your car and will clean it all out. I use google and pickup at best deal, normally 19.99 for a can.
I have used Justic Brothers since the 80's. So many people locally swear by Lucas and also BG. The BG44K is pretty spendy here - around $25.00 a can.Al-53 said:Syntech is made by Valveoline...its their synthetic line....I use thier throttle body cleaner also...every 6 months....
No never tried the JB line....is that the Justice Brothers line....I have heard good stuff on it....but again never used it or saw it local....
The Techtron has worked good for me and the sea foam in the brake booster line has worked good also...I notice much better response and smoother idling after a sea foam treatment....
AL
Best prices I have seen are on eBay. Have to watch for it. Once in a while you can get a good deal. Some dealers in many towns have it, but not something usually find in a car parts store I don't think.blivengood said:Scott, Where can I get this BG-44 and how often do you put it in your car?
Thanks
Bobby
mshu7 said:+1
Even though I use only Shell gasoline, I still use a fuel system cleaner/lubricant. Mine is an every fill-up treatment which most people don't want to mess with so I really push it too much. If you're interested in it though, it's called FP60 and you can get it from LubeControl.com. It's probably the most recommended fuel system additive on BITOG outside of Techron.
