Calendyr
- Jun 9, 2013
- 3,996
Hey guys, I received my Gloss Meter by courrier directly from China monday and today I had some time to play with it.
I would post images but this forum is amazingly hostile to image posting. Everytime I try to upload something it tells me it's too big and when I try to use image URLs from other websites it gives me an error. So, sorry, no images.
So today was a beautiful day and I only had one appointment which ended at 2 pm. I was home by 3pm so I decided to give the gloss meter a few things to test.
I have been wanting to apply a ceramic coating to my car for 3 years and never have the time. Only free time I have is when weather is bad, and I can't apply a coating in bad weather... so tough luck for me
Today was different. I knew I only had about 6 hours of sunlight left if I started immediatelly so I decided to simply cut each step a little bit and be able to do the job in 5 hours instead of the usual 7.
I took a reading before doing anything to have a baseline with a dirty car : 92.1 GU. My car is silver and the paint is almost in perfect condition. So a high gloss before touching it was what I was expecting.
Started with a pressure wash of the car
Followed by Iron Decon with Ferrous Dweller
Pressure rinsed it all off
Then did a rinseless wash with ONR
Also did mechanical decon with Optimum's clay towel. Meh. It kept sticking to the panels, not a big fan of these small towels so far. I think NanoSkin sponges are a better product. Also after doing the car the towel is all gummed up and I could not find a way to get it clean. Will have to talk to Yvan about it ;(
After drying the car, I took the first gloss reading: 96.4 GU (that is an average but the numbers varied very little between readings)
I decided to do a very quick compound step just to see how it would affect the reading. The paint did not need compounding. So I took Meguiars D300 with my Rupes ES21, slapped on a Lake Country ThinPro orange pad and did 2 slow passes on the hood. Repeated the process on the trunk. After IPA wipedown I took a reading of 101.5 GU. Pretty impressive for a compound, I would be very curious to see how M105 would compare.
I then proceeded to polish the trunk with M205. As far as I know M205 is the polish that gives the best finish, so I wanted an other baseline. I used a Buff&Shine green light polishing pad on the Rupes ES21 and did 3 medium speed passes. I could have worked it longer and probably would have gotten a higher reading but I was pressed for time
So the reading after IPA wipedown was 107.4 GU.
I then proceeded to apply CarPro Essence on both the panel that was polished with M205 and the one that was only compounded. I wanted to see if polishing before applying Essence would make any difference. I used an other Buff&Shine green light polishing pad on the Rupes ES21 and did 3 fast speed passes.
I got identical readings on both panels: 103 GU. This surprised me cause I always felt Essence gave the best gloss of all the polishes because of the fillers. So 2 things here: 1) Maybe the fillers are blocking the metal flakes in the paint reducing the gloss a little. 2) Essence being a SiO2 product needs time to cure to obtain maximum gloss. I took the readings immediatelly after application so it is very possible it would have improved after some time had passed. But it's still surprising to me that M205 had a better finish
I then proceeded to coat the entire car with McKee's 37 paint coating. This is the original formula, not the improved one. After application, gloss was reduced to 100.5 GU. That surprised me. I know it takes about a week for a coating to get it's maximum gloss, once the cure process is done... but I was not expecting it to reduce the gloss.
Finally, I applied CarPro Reload on top of the coating to protect it while it cures. Did my typical method of spraying a microfiber towel 4 times to do the first panel, then twice more for each panel after. I then buff off with a microfiber towel with very short nap.
Final reading after Reload: 97.1 GU an other surprise. I am thinking Reload needs to cure as well to get max gloss.
I think I will take a reading tomorrow to see if numbers have improved.
All and all, I think this is a very nice tool to have. When I work on cars that really need it (like I usually do), there should be a huge gap between the initial number of the final one. I know paint in bad condition can easilly get in the 50-60 GU range. So if I can get that to almost double, I think it would make for great pictures
