You are using too much. How many coats of wax does your paint have now? And when was the last time you applied a coat of wax? If your present wax is not cured then the new Fuzion with the solvents will dissolve the previous layer and start streaking. Less is better.On the subject of Fuzion I got in on the 2 for $100.00 frozen Fuzion....today was the first time I used it on a Jaguar.....I noticed is was streaky and extremely oily........so I backed off and went to the Souveran.......is this normal? or should I melt the tub completely down and mix it up?
That was my thought too (using too much, but I barely scraped the applicator maybe twice before I applied it)You are using too much. How many coats of wax does your paint have now? And when was the last time you applied a coat of wax? If your present wax is not cured then the new Fuzion with the solvents will dissolve the previous layer and start streaking. Less is better.
Did the top seem extra oily? It doesn't seem that when it got frozen that the oils would separate from the wax. Dunno. It sounds like you were only applying the oils to your paint, hence the streaking. It seems logical to heat it and try to get it to all blend together. I have Fuzion, but not the frozen special and it spreads and wipes off like butter with no streaks left behind.That was my thought too (using too much, but I barely scraped the applicator maybe twice before I applied it)
Yep, it was oily...........my next plan is to heat it up..........kind afraid to nuke it.........afraid to boil it, hair dryer is only blowing cold air........lol.......any suggestions? besides buying a new hair dryer...lol......Did the top seem extra oily? It doesn't seem that when it got frozen that the oils would separate from the wax. Dunno. It sounds like you were only applying the oils to your paint, hence the streaking. It seems logical to heat it and try to get it to all blend together. I have Fuzion, but not the frozen special and it spreads and wipes off like butter with no streaks left behind.
Use a double broiler and steam it. I've nuked waxes before on low with no issues. If you do use a hair dryer, don't heat the wax directly on high. Once it starts melting you will have liquid wax all over the place from the force of the air.Yep, it was oily...........my next plan is to heat it up..........kind afraid to nuke it.........afraid to boil it, hair dryer is only blowing cold air........lol.......any suggestions? besides buying a new hair dryer...lol......
Fuzion is a WOWO, but you can do the hood, top and trunk and come back to the hood and wipe off with no issues.I received the 2 for $100 special for my birthday. My question is, is it best to wipe it down and let it sit (haze) for about 45 minutes to an hour, or is it better to WOWO? I know that ## Pete's 53 is a WOWO type of wax. I just want to make sure i'm getting the most out of every application with Wolfgang Fuzion. I prefer to apply in the shade (garage).:buffing:
Glad it worked out for you Jarvis. Fuzion is a great wax.Surfer...thanks man.....great idea on the double boiler...worked like a charm, I went ahead and did both tubs (not at the same time) allowed them to harden..and wham o.....like a bad boy I applied to my car and gosh, no wonder this stuff is so highly regarded....its looks incredible and no streaking this time, again thanks for that advice...oh also while the Fuzion was cooking I amde a couple of Buritos too..........lol......see ya
