2016JGCSummit
- Apr 22, 2017
- 1
I finally decided to get the MTM Foam Cannon.
I have an Ryobi gas PW (2800 PSI, RY802800) and was all excited to get my foam on when I ran into a major blocker.
The quick connect provided by MTM does not lock completely into the pressure washer's wand (see images below).
I did some research and it seems this is a common issue with MTM foam cannot and Ryobi.
Some folks have suggested buying additional hardware to replace the quick connect provided by MTM however I came across a post on Adams forum where someone mentioned simply shaving off a tad bit on the MTM quick connector does the trick.
So I did just that and it locks in place now. I used standard metal file found @ any hardware store.
See attached images.
Hopefully this will help someone in the future.
