garage cabinets
builthatch
now that all my overhead lighting is done, i need to focus on storage. i am going to build an "L" shaped work bench in the nook i have off of one of the walls, but need to do cabinets. my first thought was just to get contractor grade stuff and go crazy but living in southern NJ means temperature extremes, along with humidity. so, that idea is probably out. i can picture all sorts of warped shelves in short order.
i was thinking custom - not fancy - but doing stuff in the right woods in a sturdy way. this would offer the best use of the space and maybe the most durable overall option, but cost is a major concern there.
so, what is everyone using in their space? i am particularly interested in cabinets that hang, not floor standing stuff.
I am using Kobalt from Lowes. Quality, and looks nice. They have a nice selection online.
Sent from my SM-G935V using Tapatalk
Like my gladiator cabinets. I have premier line, and its handy that I can reorganize the garage as I feel like it, however, I envision at some point in time I'll be redesigning my garage from the ground up with something like NewAge or Saber cabinets.
I have some Closetmaid cabinets...and they're okay....but wish I'd gone with the Gladiator stuff.....I live in south Jersey too...and I've not had an issue with anything warping...and these have been up for 5 years
I got mine at IKEA. Kitchen cabinets that hang from a wooden support which can be moved. Good construction and inexpensive.
Unless weight is an issue, (decent) contractor grade cabinet shelves shouldn't sag. I'd still go with a steel cabinet, though. If you aren't picky, keep an eye out for scratch-n-dent sales for either type, or along the curb on trash day.
I have Rubbermaid FastTrack running the full length of both side walls of my garage. I needed a trim piece to cover the joint between the T-111 sheet siding I used to finish the interior walls, and it works great. I have a free cabinet screwed to the wall, but I may hang it and a few others from the track at some point.
If you decide to go with a track system, consider using better screws for attachment. I used GRK Cabinet Screws - they're stronger than the included hardware, and much easier to use. They're also available in stainless steel, if corrosion is a concern.
I went with these. But pay no attention to the price. I found that salvage yard that handles some of Costco's dent and scratch stuff brings it to the TRW swap meet in Redondo Beach. I got seven of them for $80.00 each. I was able to "bodywork" the dents out without too much trouble. Biggest hassle was that only one cabinet at a time would fit in my Explorer.
Sandusky Welded 72" Steel Storage Cabinet | 36?W x 18?D x 72?H
Costco has some decent stuff, used them for my garage set up a couple of years ago. With being in a four season climate and non heated garage there hasn't been any issues
I have the Kobalt cabinets as well.
I'll put my plug in for the Gladiator cabinets. These things are beautiful and rugged at the same time. There are many varieties, and when mounted on the wall, you can do pull-ups off these things. The drawback is that they are on the more expensive side of things. I looked at these, Husky and Costco cabinets. I felt these were the best option for what I needed/wanted.
That's quite the set up!! Did you buy one of the packages they offer or did you just buy the different pieces you wanted? They aren't cheap, but they are well made and the finish holds up really well. I really like their fully assembled versions that are welded together vs being put together with screws, especially for the wall mounted cabinets.
I didn't buy any of their packages. I pieced them together by using their "build your own" designer on their website and bought various pieces from Gladiator online, Sears and Amazon to get the best prices on things. Again, I think they are awesome and I've been really happy with them.
