Garage Mods for Efficiency
DaytonaJae
If you're like me, you enjoy detailing. A lot. More than most "normal" people. However, I absolutely despise setting up my gear and cleaning up after I'm done. To me, that's just chore work that is not enjoyable.
I like rinseless washes when the situation calls for it, but on my weekends, weather permitting, I look forward to my traditional two-bucket washing with my music on and some cold drinks.
I like using a pressure washer, either for just initial blowing off the dirt before the 2BW or using a foam cannon. It's just fun. I also like to dry my cars using Metro's Master Blaster and vacuum them out as part of my maintenance routine.
The problem comes when setting up each step - plugging in the master blaster, wheeling it out to the car, drying, then putting things back after you're done. Then repeat for the vacuum.
A few years ago, I tried to optimize this process by placing the master blaster and vac n' blo on a cart. The idea was to simply wheel out the cart to do the job at hand. As novel as that was in theory, I found it cumersome and aggravating to use. It also took up a lot of space in the corner of the garage.
As you can see here, limited walking space results from the "cart". The last thing I want to do is brush my backside along the car everytime I want to get in or out (the front bumper is all the way up to the front shelf).
I wanted to change the way I did my maintenance washes. I wanted to set up my garage to be as efficient as possible for this very purpose.
So my idea was to wall mount everything in order to gain back the space around the car.
I bought some extensions for the Master Blaster as well as the Vac N Blo units, since they will now be staionary. I had to buy the mounting bracket for the MB as well, along with some hose hangers, wall hardware (Tapcon) as my garage wall was concrete block underneath stucco.
Here was my original idea
(Special thanks to SizzleChest for bringing his hammer drill and helping me do this)
Somehow it didn't look right. I tried to utilize that small area between the door and the wall for the units, which would minimize the loss of hose length that is useable, but it just didn't seem right to me.
Also my pressure washer needed replacing. It worked fine, but hated how it had no cord management, and it wasn't wall mountable. Trying to find an affordable, basic use, wall-mountable unit was almost impossible. Until I saw this on Pinterest...
This was a pin from Lowe's. It shows one of their Greenworks pressure washers mounted using a hanger on a wall. I researched it a little and found that it uses standard 22mm connectors for the pressure hose. That means I can use a single 50-ft. pressure hose instead of having two hooked up together. Perfect. I have a Lowe's card. Even more perfect. I ordered it online and picked it up that evening at the store.
Within an hour, I had it mounted on the wall.
My plan was to use my existing hose hanger above the unit to hang the pressure hose.
This made me think of a better idea for mounting my Metro units. So, A few beers, a new hammer drill (my very own!) a bunch of Tapcons and even more mosquito bites later, I had this:
Ok so this is starting to take shape. All I needed now was to add an extra gang outlet to the existing electrical box I had installed for this purpose, then clean it up a little.
Here it is done with a cover and 4 outlets wired to a 30 amp dedicated breaker inside the main panel to the right. the left side is GFCI and the right side is not. There is no way I can use more than one of these outlets at any given time, unless I can somehow dry, vacuum and pressure wash the car simultaneously, so there are no issues with the amperage.
Here is what it looks like, almost complete.
The above picture shows,
1. Master Blaster with Metro Wall Mount and two hose extensions (total of 30 ft.) Extensions were reinforced by Gorilla Glue as per Metro's recommendations.
2. Master Vac N Blo Wall Mount version - shown with 3 hose extensions (most likely will add a fourth).
3. Suncast hose hangers with built-in storage, mounted above each unit.
4. Greenworks 1500psi Pressure Washer with a generic hose hanger mounted above it and a 50' pressure hose with 22mm connectors, using the stock Greenworks gun. An additional hanger was installed to the right of the washer to hang the gun due to the size of the longer hose interfering with the built-in holster on the unit.
6 ft. leader hose connected to the left of the pressure washer with a male quick-disconnect attached to the outside end.
My outside water source (garden hose reel) sits just outside that wall (you can see it just outside the door) with the female quick disconnect and shut-off valve. This keeps any water that may flow out when I disconnect the ends to be towards the outside and not further into the garage.
I have ordered some cable covers so that I can route the power wires to the outlet and keep everything plugged in. When that is done, I will post the final pic, then testing to see if this is easier to use than the previous setup!
I welcome any suggestions to further optimize this setup.
NICE!!!! Great little set up you have. Thanks for sharing!
Awesome idea!!!!! My problem is always having places to leave all my mitts and brushes to dry. An over the door shoe hanging rack mounted on my wall works awesome!
Looks great! I have been meaning to wall mount my Master Blaster too... can you show some more details on the wall mount? Is the MB unit totally secure from falling? It appeared to me that the unit could fall if accidentally bumped side to side... any info would be nice! Thanks :)
Nicely done. I need to get my Metro vac off the floor as well. Nice ideas.
The newly organized area looks great!!
About your receptacles...If I'm not mistaken branch circuits for receptacles can only be 15 or 20 amp and never 30! What size wire did you use and what amp rating are the GFI and other receptacles?
FYI- I am not an licensed electrician
The mount is a single piece of metal that is mounted on to the wall using 3 screws. How strong it is depends on what you mount it to. In my case, I mounted it directly into concrete block using 3 Tapcon screws, pre-drilled. That mount is very sturdy and I can most likely do pull-ups on it (if I can do a pull-up lol) Most likely hang from it without feeling like it's ever gonna budge.
The way the unit hangs on the mount itself is a simple bar that extends between the front two wheels (or whichever set of wheels you want to mount the unit. In my case, I mounted the unit from the rear wheels so the output faces downward.)
The hanger's design makes it somewhat impossible to accidentally knock off the wall. You'd have to lift up the unit about 1 inch in a backwards direction to clear the lip of the mount. I'll take pics of it in more detail later on today when I get home for you, it's difficult to explain in words.
It does sway side to side if you brush up against it, but impossible to have it come off the hanger unless you physically try and lift the unit up past the lip, and as you know, the master blaster isn't a lightweight unit.
I was really afraid of it coming off and hitting a car in the middle of the night, etc... I mean, what detailer isn't afraid of something like that? But I feel very secure in the rigidity of these mounts.
Wow very nice!! My garage is set up for working on a car at night but not like your set-up. Thanks for some ideas!!! Awesome garage stuff!! A garage is a mans castle!! Everything else is the woman's!!...LOL
With those hose extensions for your MB, will you lose air force output?
^this is my ultimate fear.
After looking at the mount, I now understand that the wheels restrict the side to side motion so the unit doesn't simply slide off. Makes sense. Still a rather hefty price for a basic bent plate and some hardware :/
Maybe I will fabricate my own.
Yes, you do lose some air output with 3 extensions on it. From my un-scientific observations, through nothing but overall feel while using it in this configuration, I would guess that it feels like I lost about 25%-30% of the "kickback" force while in use.
Now, granted, this master blaster is overly powerful to begin with, so it still had plenty left and more than enough to dry the car, wheels, blow the droplets off the other side of the hood.
The Vac, however, with 3 extensions on it, still attempted to pull up the carpet with no issues, so I can say that it doesn't feel any weaker on suction even with the added hoses.
At one point, in a previous thread, I found information that stated there would be no noticeable loss in power at the nozzle with a hose that was a total length of 20ft.
EDIT: Found the post.
This is the response I got from Metro Vac. :xyxthumbs:
Thank you for your email.
You will not be able to detect any loss of power when extending the hose another 10 feet. If you choose to extend the hose I recommend using gorilla glue and permanently adhere the two hoses together.
Should you have any questions, please feel free to call or email.
Thank you,
David Stern
V.P. Marketing
Metropolitan Vacuum Cleaner Company, Inc.
Toll Free: 1-800-822-1602 Fax: 1-845-357-1640
EDIT - I reread your post and noticed you said 20 ft. Sorry.
I have two extensions on top of the original for a total of 30 ft. which in my trials, is necessary in order to reach the rear of the vehicle when parked in the middle of my driveway.
I've used this MB since I bought it at DetailFest 2012 and I can tell you there is definitely a noticeable loss in power with 30 ft, that's for sure. How much remains to be determined but the result, as I said, is more than enough still for my needs.
An added bonus for having these mounted inside the garage is the noise level goes down a bit while in use, since it's no longer right next to you while in operation. You still get the occasional whistle when it hits your lugs, as all MB owners know can get deafening.
I'm not either lol...
I called a couple electricians in the area but nobody was interested in such a small job, so I YouTube'd it and learned how.
I have 10 gauge wire going from the panel's 30A breaker to this outlet. So I used 10ga. wire from the load terminals on the first GFCI outlet to the new, non-GFCI outlet that I added.
Yeah the outlet only handles 20A and the breaker is 30A.
First class all the way Jae :props:
This investment of time and a few parts will give you years of efficient detailing pleasure.
Throw a CR Spotless in there and you have my Dream Set-up!
Looks great
