donavin629
- May 23, 2009
- 46
RV Gelcoat with heavy oxidation.
Im having an issue with these darn RVs again.
Would love to get your ideas and feedback.
1st Washed the vehicle
Tools used
· Makita high speed buffer
· Cyclo machine
Tried to use system one polish with a wool pad and it removed the heavy stuff and brought back the shine.. but when you look at it from an angle you can see blotchy marks and even patterns left from where I was buffing back and forth and up and down.
Went over it like 3 times still left with these shadows.
Turned to cyclo with yellow cutting pads with system 1… same issue.
Turned to compounding with wool pad… yellow cutting pad.. highest speed.. low speeds..white polishing pad with low speeds.. high speeds.. I tried it all. .. same issue.
Next went to a boat dealership and talked to the detailer… he had meguiars 44 color restorer and meguiars 45… same issues with the blotchy markings.
Next the shop foreman gave me some 3m 5995 Foam Polish Pad Glaze and a dewalt buffer.
He also was using a 3m white pad.. which he said was a polising pad.
He did a section using this method and it was not perfect but it came out a lot better.
Only thing I can think of is because he was running it at faster speeds.. so I started using this method with the 3 m polish and using the dewault at 2600 rpms… it was coming out a lot better.. but not perfect.. how can I get these markings out? The foreman said the customer wont probably see them.. and I cant expect to get an RV with Gel coat perfect if it has not been taken care of and is heavily oxidized. i wont accept that.. i need perfection .. it will drive me crazy lol
ANY IDEAS? FEEDBACK.. HELP????
Thanks everyone… .also check out my new site.. let me know what you think.
i know the images is hard to see but you can kinda see the zig zag marks in the circle
Tools used
· Cyclo machine
