General Spotless Water System Suggestion
YankeeFan
Just an FYi so this doesn't happen to you. That is to check to ensure the two frosted tubes are intact.
I've been using the Spotless watering system for about 5 years with no real issues. Washed the car today and as always I took the 2 inner tubes out to drain so they don't sit in water all week until my next wash. Well, as I dump out extra water from the outer blue tubes I see resin at the bottom of the output tube. Damn, the glued portion of the inner tube bottom was slightly weakened as I was able to rock it back and forth. So, without seeing it I had small particles of resin in both buckets. Now I have some light swirls back after having polished the car about 6 weeks........bummer....
