Getting rid of micro marring
NFA
Was working on my brothers heavily swirled black 04 Lexus IS300 this weekend and noticed there was a lot of little micro swirls on the finish still if I looked real close with the Brinkman. Ultimately I had to step up with a LC Cyan Hyrdo pad and M105 to get most of the swirls off. That left a nice little haze, but was able to get it finished down with a LC Green CCS pad and M205. And even still, I could still a little micro marring on the finish. Is there a intermediate compound I should use between M105 and M205 or is there another pad combination I should use?
Also, it seemed that Lexus is using a single stage paint on the blacks? My pads came out black.
What it sounds like to me, and I'm no pro so if im wrong others please feel free to correct me, but what it sounds like is that you are going from one end to the other with no in between pad. Try finishing down with a white lc pad and m205. I believe the green pad is for AIO with light cutting ability.
lexus clear is also pretty soft so polishes with dimishing abrasives finish down nicer than 205.
Try some Menz 106FA or 85RD on a white flat polishing or black flat pad for a flawless finish on lexus black
lexus also uses tinted clear on black which is why you are getting colour. If it really were single stage, your pads would be coal black, not just a little black...
I would suggest adding a medium polish like Mmenzerna Power Finish or Meguiar's Ultimate Compound in between the compounding and finishing polishes. More importantly then that though, I would finish off with a lighter pad like a LC Black or White pad. Additionally you could add one more step such as Menzerna P085RD to really provide a haze/marr free finish. A lot of people have had great luck with P085RD on paints that marr easily. Good luck and let us know what works!
Sent from my DROID Pro using Tapatalk
