Has anyone used the HT 3in vs. GG 3in pads? I know the MF have been recommended.. I just have never used a MF pad.
If I want to use it for headlight sanding is it the 3 inch foam interface pad that I would need?
I've seen the rupes white 4 inch suggested for wax.. It describes the pad as a polishing pad... will that work for wax and/or sealant application? Does it have any cut?
I haven't pulled the trigger on GG3 yet... but am close.. Finalizing thoughts on pads... For light correction, wax/sealant application etc. the newer version should work fine correct?
- Thx
- Thx
