Shortspark
- Jun 14, 2012
- 671
Yesterday I ordered a Gilmour 75QGFMR Foamaster Adjustable Foam Gun. I like to use CG Clear shampoo, which is also suppose to be excellent when used in a foam gun. According to directions supplied by CGs, the dilution ratio for Clear when used in a foam gun or cannon should be 1:16, ie, 1oz of the Clear shampoo to 16oz of water.
That is easy enough but it becomes complicated because the gun has dilution ratios built into a sliding pin mechanism of some kind, which can be adjusted to a wide range of different ratios. I think the gun can be set to shoot from one ounce of product per gallon of water all the way up to 12oz per gallon.
So, my question is where should this pin be set? Should it be to the highest, lowest or in-between setting? I will experiment in order to achieve good foam of course, but I don't want to waste soap either. I intend to make a 1:16 solution as per the instructions and pour it in the gun, but then I don't know where to set the gun's internal ratio adjustment. The reason this is important is because Clear is safe when heavily diluted (1oz per 4 or 5 gallons of water) but by increasing the ratio of shampoo and making it stronger will strip LSP and I want to avoid that when doing in-between full detail washes . Anyone have ideas on this?
