A4 1.8tqm
- Apr 4, 2009
- 1,932
After installing a 6000 K. HID headlight kit my friend got me for Christmas, the stock fogs on my '99 A4 were looking pretty dull by comparison. I considered buying new ones but decided to at least try and restore them first. The only thing I could think of was to fill the chips by spraying clear coat, wet sand and polish to a nice clear surface, but will it work?
Here's a couple of before pics-
First thing I did was give the entire lights a wipe down with Megs APC+ to remove any loose debris. Then the glass got scrubbed with a brush and IPA, wet sanded with 2000 and then re-brushed with IPA to ensure a clean surface for painting.
The one on the left is after one coat of clear, unsanded.
Here is a close-up of the first coat. Many of the small pits are filled in, hopes are high.
After a second coat It got a light wet sanding with 800 grit. I used a soft block with "single swipe" sanding, back and forth just felt too aggressive. Then more light sanding with 2000 grit.
Here is a third coat, sanded with 800 then 2000
Before and after, the final coat applied but unsanded (After finishing the other one I left them to cure over night before polishing).
Did you notice the Sonicare tooth brush in an earlier pic? Immediately after each coat of clear I took the vibrating toothbrush and pressed it to the light's housing, in various places and pressures. The goal being to shake any air bubbles out so the clear can completely fill the pits. I just did this cause I thought it was a good idea. This next pic is the one time I forgot to "vibrate". It dried looking like this and I ended up peeling the clear off, re-prepping the surface and starting from scratch. :doh:
Here they are the next morning after 800, 2000, Menz power gloss, Menz IP then 3M Ultrafine.
The big question is how will they look next week? Six months? A year? Only time will tell, but I happy for now!
