Mgavin1985
Member
- Nov 25, 2017
- 500
- 2
Does anyone have any idea what this is made of? I used it for a while and I love the look of it after it set for 12 hours. I was wondering if their was silicone in it?
See below.Does anyone have any idea what
this is made of?
Unless its formulation has recently beenI was wondering if their was silicone in it?
great stuff, i don't bother buying aquawax separate anymore, just mix up a batch of the rinseless wash (w/aquawax) at 10:1 and you'll have one slick finish with some protection...
I do what kinda of ratios do you mix and what are you doing a rinseless/waterless type. Everything might be a wee bit better with aqua wax in it.
Mix the Aquawax with DG FCS at 1 part AW to 3 parts FCS. One of the brothers from DG recommended it as a drying aid. Apparently, AW, if used too often, can cause some cloudiness from wax buildup, though I've never experienced it myself. Adding the FCS to the mix eliminates that possibility for those that use it with every wash. I use it with either a Rinseless wash or a soap/bucket wash and also as a QD.
If I'm doing a waterless wash, I just use DG, Ultima or Optimum waterless by itself.
Bill
