Got Pressure Washer - What Products?
KneeDragr
I got a Karcher K3.740 for X-Mas, now I need to know what products to get with it - and how to use them.
I have the AutoGeek Pressure Washer Foam Cannon in my shopping cart - what else?
Ive heard people say CG Wash and Gloss - I looked and it had no instructions for use in a pressure washer.
I guess I need an everyday foam soap, and something to disolve/remove LSP.
I use cg wash clear for daily use and stripe lsp with different dilution. 0.5oz per gallon for 2 buckets wash and 1oz with rest of water for foam cannon. Turn your foam cannon all the way to negative, you should get probably 10+ wash out of it
Megs Hyper Wash foams like you wouldn't believe it. Plus, all you have to do is put an inch of it in your foam lance and fill the rest with water and u will have one thick foam for ultra cheap. Also, you can use it as your normal wash soap as well.
Dont use CG, there products I find are hard to get off completely.
