Great looking interior porsche 911 - pit stop detailing by KC
kc's
I had this wonderful opportunity to be able to help my buddy to beautify his interior....but there is TIME & COST effective ...limitation issue... he needed the ride in less than an hour.....
most commonly problem for any germans ride.....my bud thought Malaysia is too hot...so hot till the knobs in his ride melted....as you dont find in any other ...as they are not rubberished
common know issue in other German Marque Machine too....esp in E60s
intervention plan as following:-
1. wash & dry within 15 minutes - ONR No rinse wash
2, wax within 10 minutes - Optimum Car wax (spray, wipe & walk away)
3. interior detailing -
*door panels - clean within 10 minutes ( Optimum power clean - & brush off)
*dash & seats quick wipe down with a damp Microfibers 10 minutes (highly recommended weekly)
*leather & interior protected by Leather protectant plus (another spray, wipe & walk away) is good for all interior plastic, vinyl & rubber - 10 minutes
total time spent 55 minutes
ta da to here
remember before
By cleaning with Power clean & microfibers
moving on ..........interior
a special techo time...speciial edition comes with PSM .. Porsche Stability Management serving to intervene in the engine management and brake system in order to stabilise the car in both longitudinal and lateral direction whenever the car is driven to - or beyond - the extreme.
Leather cleaning....
recommended soft hair bristle brushes
ta da
now the dressing time
(a spray on , wipe off & walk away) is good for all interior plastic, vinyl & rubber
many door jams rubber faces the dull looking & whitish powdered finish
a dull looking interior....unattractive vinyl
picture before
ta da
just a soft touch
another breakthrough invention...leather, vinyl , plastic
now this is the most optimised looking vinyl & protected against UV & the heat of the tropics
another hidden compartment in the trunk
before
a well detail trunk & the secret chambers
thanks for taking your precious time in view another detailing tale again
now the horse is ready for its knight to charms his princess...
knobs are misleading... you took a picture of the left one for before and then the right for after.....they were in two different conditions... you can see that on the 6th picture when you see both...
my apologies ..oppss ...
.let me return to the owner & shot the other side ,, you can actually see
from this if you enlarge this pic
another
will return to shot it close up ...stay tune
