Grilling in Garage = Greasy Car?
AirVenture
I had just cleaned my car in the afternoon and grilled out that evening. It was really windy and unseasonably cold here in TX, so I had my grill nestled just inside the open garage door. Today I go to drive the car and notice it's covered in a very fine, speckled coating. It certainly seems greasy. Could it be from grilling? I've noticed this same thing once or twice before, but never made the connection. I figured it was overspray from something. In this case I'm fairly certain it isn't overspray, as it looked perfect the night before.
Any ideas? Does burger grease make a good wax? :)
From your story its more than likely grease.. use a good soap and you should be fine // put up some kind of barrier in the garage, or car cover which I don't recommend, or the grill's going back outside!
Well, grease is hydrophobic, but, as I remember well from my youth and wearing good old Murray's Pomade, it tends to magnify the sun's rays. Soooooo, yeah. ;)
Realizing that eating beef tallow is reknowned for its "clogging-effects"...
I hope that none was ingested into your vehicle's 'life-lines' when you started it up.
I'm also glad that you didn't burn your garage down.
Easy solution.
07180926000
I've seen this model on clearance at Sam's club for under $200.
Grilling in a garage is potentially dangerous. Also messy and smelly if you are grilling things like steaks that render fat and smoke a lot. In that smoke is grease, as you found out. That same grease and smoke will embed odors into your car(s) and garage. It also might make a good lure for grease loving ants and other bugs.
Good points!
I usually buy 95/5 or 97/3 ground beef, but family was in town visiting and they bought 80/20. Yuck. The grease was causing all sorts of flare-ups.
That's a nice canopy. Looks like it would hold up well. Hopefully next year I'll be able to afford a porch addition, otherwise a canopy might be the way to go.
I live way out in the country. I wouldn't be surprised to see a goat licking my car...
I hope my fuel lines aren't clogged with cholesterol now...
It's probably grease. Now you have an excuse to use dawn and re-detail your car. lol
It's not a good idea to grille in the garage though, for other reasons than grease on the car.
