Dont they have the same internals, just externally different? If so, I'd get the second gen, it's prob cheaper, but same guts, different shell.....may be wrong though
I have the second gen and I would recommend the third gen. The switches are in super inconvenient locations.
I like LC pads but you should try the CG Hex Pads also very nice. I just demoed LC CCS, CG Hex Pads & LC Hybrid pads on a Flex 3401. All nice pads. Previously used the CCS & Hex pads on a PC and RB.
Thanks Just placed my order
Went w/ the 3rd gen. only 10 bucks more had them match a competitor and switch out to the 5" backing plate and I had 20 dollars off AG BUCKS plus ordered these pads
Lake Country CCS 5.5 Inch Foam Pads
Orange
White
Green
Gray
Blue
Red
:buffing:
Congrats! You are about to have some serious fun brother.
(Hope you got 6X multiples of the white, green & gray at the very least)
Later,
Cardaddy
Yeah I'm looking forward to it... Doing 2 new clients this weekend
I actually just bought 1 of each.
wanted to try out the LC pads
also planning to place a small order for some CG Hex pads and see what I like best.
Then I will be purchasing more of the pads I prefer to work with
You are going to do TWO cars this weekend with only ONE pad of a given color? Yikes!
How are you going to do a test spot to figure out which one works, then pick *that* color to finish? :doh:
Honestly though.... I don't know anyone that does more than a normal sized panel with a pad, pushing one pad through an entire hood or roof is at best dangerous. And can be catastrophic.....
If doing compound, polish, sealant & wax on a coupe I'll go through 15 easy. (2~3 being for sealant & wax)
On an SUV that number goes past 2 dozen!
One step OTOH can get away with maybe 6 to 8 depending on how many swirls can be corrected (well not actually corrected like compounded but at least helped) with a polish/sealant combo product.
Later,
Cardaddy
Wait, how many??????? 2 pads per hood? Wow, I think I need new pads!
Sent from my Galaxy Note II using AG Online
Yeah 2 pads per hood is a bit too much. I use 1 pad per hood, clean often & on the fly!
I'm both messing with y'all and being truthful at the same time. Sure, its possible to do a hood with 1 pad (if it ain't huge) but you'll use another one for the polishing stage. Ergo 2 pads minimum.
OTOH if it's old or dry or needs tons of work, 1 (foam) pad will overheat long before it's done it's work and have to be changed out. Especially if working with a lot of cut. :dunno: Before that happens I'll do a 'clean on the fly', lay it down to cool and pickup another one to keep on going. Can still go back to that pad later and use it till it's time to pull it outta' service. Either way that's 2 pads. :xyxthumbs:
Just found that it's easier, faster, and does a better job to change pads often. Plus I believe anyone that's done it before knows there is simply no way you'll do an entire car with less than 4 ~ 6 pads much less 1 or 2. Adding to that you MUST take the time to clean them, and (hopefully) let them dry, and try to do another car the same day.... just not gonna' happen.
100% agree. The 3rd gen is much better ergonimically better too! I had a 2nd and traded with a friend for an XP. Sold the XP and bought the 3rd because the XP is under powered in comparison to either GG.I have the second gen and I would recommend the third gen. The switches are in super inconvenient locations.
