Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Griot's BOSS G10 Pneumatic Polisher - Air powered 10mm dual action polisher!
Richard Griot and his team have hit another home run!
The new Griot's BOSS G10 Pneumatic Polisher is the BOMB!
Nick came into my office yesterday and asked me if I could take the new Griot's BOSS G10 Pneumatic Polisher out for a test drive? I said…. hell yes! I have a 1939 Chevy 5-window coupe coming in for a show car makeover and a 1985 GMC Van coming in for an extreme makeover!
1985 GMC Rally Van
My comments...
Superb fit and finish
When I removed it from the box I was impressed with the appearance of the tool. The fit and finish for all the components are tight and exact. There is no sloppy feel or look to any part of the tool. It feels like quality when you hold it in your hand, it’s a pro grade looking and a pro grade feeling serious air tool.
Power and performance!
When you hook it up to your air line and turn it on you’ll be just as impressed by its operation as its performance matches its appearance. The tools operation is smooth and balanced, without vibration throughout the OPM range. The thumb throttle is perfectly located to enable you to power down or power up with the press of your thumb throughout the OPM range.
Correction work
Griot’s new BOSS G10 Pneumatic Polisher has TONS of power! So pad rotation is never an issue. This means there’s plenty of power for doing correction work with both microfiber pads and foam cutting pads.
Polishing
The 10mm orbit stroke is perfect for polishing paint to perfection! The tool feels smooth in your hand without vibration for easy polishing any car any paint.
Waxing
The thumb throttle provides absolute control over speed so when you’re ready to machine apply a wax or synthetic sealant simply reduce the speed to quickly machine apply a layer of protection.
One word... impressed! :dblthumb2:
Air Polishing is HERE!
If you’ve been dreaming of an air powered dual action orbital polisher then it’s time to WAKE UP! Because your dream has come true.
I was around back when people tried to use the old style pneumatic palm sanders as dual action polishers. While it kind of worked… they just didn’t have the power to do the job. Not so with this new Griot’s design. Don’t let its lightweight, compact design fool you because this tool can get the job done.
Get yours today!
Autogeek.com
:dblthumb2:
1985 GMC Rally Van
My comments...
- Lightweight.
- Compact.
- Ergonomic design.
- Use with compounds for removing swirls, scratches, water spots and oxidation.
- Use with polishes to perfect paint and maximize gloss, depth and shine.
- Seal the paint using your favorite car waxes or synthetic paint sealants.
- Machine apply your favorite cleaner/waxes and AIO’s for one-step paint restoration.
- Versatile - use it with Griot’s microfiber or foam pads.
Correction work
Polishing
Waxing
Get yours today!
Autogeek.com
:dblthumb2:
