I took my Griots G15 polisher for its first drive today. I was most surprised that the griots backing plate did not provide the firm grab with my LC Hybrid pads and hold them firmly in place. As a result, the pad would shift to off-center and require me to stop and recenter the pad on the backing plate.
The griots backing plate did not hold the pad firmly and made me wonder if the pattern of the backing plate and the fabric on the pad were somehow incompatible. Frankly, it was horrible. The pad would slip and become off center (usually if the pad was on any surface that wasn’t completely flat) which then made polishing impossible so I’d have to stop and recenter the pad. This happened on all sizes. This never occurred with my Flex and its standard backing plates.
Has anyone else experienced this? Is Griots backing plate a different interlocking pattern? If so, is this an attempt by Griots to make you use their pads? Is there a different backing plate I can use? Frankly, it made this first experience horrible and time consuming.
