Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Griot's Garage 3" BOSS HD Orbital Backing Plate
Would you like to get MORE use out of your Griot's 6" Random Orbital Polisher?
Then get the NEW Griot's Garage BOSS 3" HD or HEAVY DUTY backing plate!
The Griot's 5" backing plate on the left and the NEW 3" HD backing plate is on the right.
Simply remove the current backing plate and install the new HD 3" backing plate.
Here's a tip - be sure the compression washer is always in place when swapping backing plates.
Here's another tip, insert the spindle wrench from the opposite side of the counterweight as there is more clearance for the wrench between the shroud and the backing plate when tightening down the backing plate.
The NEW Griot's BOSS 3.5" buffing pads fit the new 3" HD baking plate perfectly!
With the new 3" backing plate installed your Griot's 6" Random Orbital Polisher is ready to go to work!
The smaller 3.5" buffing pads make it easier and safer to buff around components like door handles.
Perfect for buffing thin panels...
And perfect for buffing out thin components...
On Autogeek.com
On Autogeek.com
