Griots Garage ceramic glass cleaner
Coatingsarecrack
From Griots:
“Ceramic Glass Cleaner features advanced silane polymer technology combined with SiO2 to clean and protect your exterior glass in one simple step. This unique formula easily leaves behind a crystal clear, streak-free finish while adding hydrophobic and durable protection to all your glass surfaces.
Superior water beading quickly repels water, increasing visibility and safety during wet weather driving while keeping your glass clean and spot free longer. Helps prevent water spots and snow, ice, sleet, or road spray from building up and sticking to your glass. Not only great for automotive glass, use it to protect and keep exterior glass around your home or garage cleaner longer too.
Can also be used as a topper over Glass Sealant to increase durability and performance.”
So back story i’ve been pretty disappointed in Griots glass sealant. Product works well but can’t apply under 50 degrees. Usually under that in fall and winter and I don’t have a heated garage.
Makes product kinda useless when i need it most.
Was looking for something like this as i usually clean windows 2-3 a month during rainy season. Clean moms rav 4 when i get a chance but isn’t driven much but windows are coated so will test on that as topper.
Applied to Camaro today. No protection on glass. Was clayed end of summer.
Cleaned just like i normally would with waffle weave towel.
Windows hadn’t been cleaned in 3 weeks but was fairly clean. Felt more like applying Ceramic speed shine.
Wiped, flipped and wiped again. It did need a final buff with another MF. Came outcas streak free as i could tell with garage lighting (crappy) and overcast weather.
If it works its a great idea. Griots doesn’t recommend more than 1-2 times a month. Use regular glass cleaner in between.
I wouldn’t use on really dirty glass. I feel it doesn’t clean as well as a good glass cleaner. That may be the protection.
Smells just like CSS.
Will post rain pics hopefully tomorrow.
So did apply to Rav4 which is sitting out side. Was also raining. Not the best idea i’ve had so decided to skip adding it.
To my surprise it’s working….
Before:
After:
What i tried to do was pull underneath over hang of roof. Wiped off water. Was still getting rain on from the sides.
The CGC didn’t spread well with the water. Used two drying towels just to clean off and there was streaks.
Got it mostly clean and gave up. Beads well but don’t know how long it will last on this car.
It’s a simple to use cleaner with some protection in it, smells amazing and really is streak free. I wouldn’t put it over CarPro Forte, but it works well enough.
Same Windshield with a night of rain.
With such janky application, surprised it lasted the night.
Decided, what the heck and "applied" it to the cars last night. Was going to wait until I could do a deep clean on the glass and leave my car inside at work (it's been sub 35° all week) so it would have a chance to cure. But, we're supposed to get 5-10" of snow, and any slick on the glass is better than no slick on the glass. :D
Cleaned the yuck off the windows with Brilliant Finish Rinseless at 1:6 first, wiped dry then sprayed on the Ceramic Glass Cleaner. Spread with one PFM Detailing Towel, allowed to set for a bit, then buffed off with another fresh PFM Detailing Towel.
I'm not expecting much - kind of like your sub-optimal conditions, it was low 30's in the garage last night, so I'm sure I probably buffed off most of what I applied. :laughing:
For my car, I'm also up against at least 165k of pitting (that's how many miles I've put on, while the windshield has the Audi rings on it I don't know that it's original. If it is, then the glass has 265k worth of wear...)
It started snowing here about a couple hours ago, interesting observation - while the other cars in the lot have your typical white blanket starting to accumulate, my car so far has more beading/runoff instead. Tapatalk photo to follow. Looking forward to seeing how snow/water behaves in motion on the way home.
Again, mainly what’s interesting here is how the other cars are blanketing over, while my (also ice cold) car is doing this.
Been great for the 5 or so days i’ve had it. Works as good as there glass sealant in NW rain for me.
Unlike other i don’t love there glass sealant but works as well as anyrhing else i’ve use.
This gets a major W though as i can add protection while cleaning and add protection.
I’m trying to shorten process where ever i can and this is my new glass product.
Still want to try quick view but unless it’s absolutely amazing will probably stick to this as it is less work.
I used today after a wash, I did all windows including the roof which is all glass
I found it to be really grabby to remove, not really any streaking but not a breeze to use by any means .
Anyone else have this issue?
I used it today first time.
Cleaned the glass like normal with Spray Away then did it again with the Griots Ceramic Glass Cleaner thought it wiped away pretty easy and left it very clean and clear.
On my drive back to work while doing that at lunch I was pleasantly surprised how clean and clear the glass was.
Will try it more this weekend for more info….
Can't say I had this issue. What did you use for towels/method?
I used one PFM to apply, one to buff off. Didn't notice any drag.
Update after driving that day I shared the windshield picture - Being first snow of the year, I completely spaced that once I started moving all those lovely water drops will refreeze at the top of the windshield instead of blowing off. :laughing: So, couldn't use my typical summer approach of skipping the wipers and just letting all the water group and run off. But, I'm happy to say the Ceramic Glass Cleaner plays well with the wipers and I didn't have a lick of chatter or streaking.
Depending on what the water load is like after the car's been sitting, I've seen runoff starting as early as about 35. I'd be curious to see what other folks observe; as mentioned I've got a pile of miles on that windshield so I'd think the pitting is working against me no matter what product I use.
I think it was my towel..brand new never washed...I did one window in the house with a different towel and it seem to work better.
I am going to use some on our glass shower doors and see how it holds up.
Wasn’t grabby on 1st application. Was today with a diamond glass towel. I think towel makes a difference.
Good protection though water flew of the glass when blow drying the car. About 40mph water starts moving
I'm really curious to use this as an LSP as a test, it really smells and acts like 3 in 1 ceramic wax to me.
Maybe Ill do it to the neighbors hood when he's not lookin......:D
I put two coats on a glass shower door I am going to be interested to see how it holds up. I did do a good job of cleaning/prep work before hand so should be interesting
Did the dog give it a taste test?
Lol yeah he said they must have put peanut butter or a tennis ball in the formula because nothing else would taste that good!
Yeah all their ceramic products have that smell. Mike Phillips uses Sonax glass cleaner for prep washes before polishing so glass cleaner aspect shouldn’t harm paint.
Also they now have it in Aerosol just in case you really hate the environment.
Kidding aside i wonder what would be benefit?
I think the Aerosol is for people that want it to cling to the glass so it doesn't run off.
I for one don't like a bunch of air mixed into mine, you can't really tell how much is product or how much is air foam
