AZpolisher15
- Nov 9, 2015
- 1,419
Is it necessary to strip previously applied waxes/sealants with a product like griots paint prep before going in with polish on a DA? First time-er here with a DA. Your insights would be appreciated.
Is it necessary to strip previously applied waxes/sealants before going with a polish on a DA?
It is necessary to prepare the paint for polishing (wash, decon (optional), clay) .... which will provide you the following benefits:
1. Embedded contaminates would be removed, which will help reduce marring/swirling when polishing
2. Allow you to inspect the virgin paint surfaces so that you can understand how to address your polishing needs
You get #3 as a byproduct... which is that previous applied wax/sealant layers would be removed. Griots Paint Prep or any other pre-wax cleaner would be used after claying; especially if the vehicle in question is a daily driver.
The only time the above steps can safely be reduced or eliminated is if you have a garage queen; and then you would simply eliminate the decon and clay steps.... assuming you are sure the surface is ready to have some steps eliminated. The baggy test is the best way to find out.
^^^To me: Sounds like a bunch of "Ad Hype"^^^
Wondering if you have ever used it?
I gotta' agree that you sounded like an ad for the product. Perhaps you just copied what GG says. Or you should be in sales for GG :xyxthumbs:FUNX650,
Back in the day, Opti coat 2.0 Dr G, was saying CarPro Easer was causing bonding issues with Opti coat 2.0. Yes I used Griots Paint Prep as a wipe down product. No problems with bonding and still on cars I coated.
Then Dr G started IPA prep was the proper product. Now they have a complete line of products for start to finish with Optimum car care products.
Your comment if I ever used the product was a directed at me personally. I will take the high road about this, sir.
Thanks to each and every one of you for your insight![]()
