tuscarora dave
Active member
- Aug 21, 2009
- 5,408
- 11
I recieved a call from a regular client today who said, "Tuscarora Dave do I have a job for you!!" He then told me what he had and I went over to have a look.
I did a test section using Poorboy's World Pro Polish and purple foamed wool pad on the Flex DA. The sheet aluminum test section came out pretty nice and he was very happy with those results.
Where I need the oppinions here is on the cast aluminum corners and other various cast parts. I want a clean look on them and NOT polished. What my vision for the cast is, the cast aluminum clean with the pours as clean as I can get them. Beside the polished up sheet aluminum I believe that will look pretty neat. Also what do you all think could be used to protect this thing from rapid oxidation?
The cast parts are on the front, the front fenders and hood are riveted to the cast corners and just below and foreward of the side view mirrors and on the top front and rear corners of the box.
The test section is the last photo.
