MarkD51
Active member
- Oct 15, 2012
- 3,130
View attachment 14414Hello All, A few weeks ago, I decided to try this product on a whim, and purchased the 30ml Bottle.
It was a personal moment of insanity, and one can further understand why when they have the product in hand, and see the ridiculously small bottle.
The product simply comes in a sealed bottle, with a few Applicators which look like small Cosmetic Face Buffs.
So, I had some time today, and decided to clean up, and detail my 1997 Tahoe's Rear Step Bumper while I had my Cover off the vehicle.
Temps here were about 60 degrees, and I was outside, and in shade.
I first wiped down the entire Rear Bumper, including the Step Pads, and wrap around Vinyl Trim, and as well the Rear Tailgate Handle with full strength 70% Alcohol to strip the Bumper of any other products present.
These most like consisted of Optimum Tire Shine on the Vinyl, and Collinite 845 on the Chrome.
Once completing this step, I then simply went on to wipe the chrome clean with a MF Towel, and then masked off all Vinyl Trim with Green Painter's Tape.
The product has a somewhat strong smell, hard to describe, it's almost a smell I recognize from somewhere else? The product seems volatile as well.
Application was fairly easy, and as I applied, I did note more dirts, and black from the vinyl accumilating on the Applicator Pad. About the Pads, I used two from the Pack for this task.
The product applied similar to like one applying something like an Armor All product, coverage was relatively easy, and I only had to apply a second coat in a couple strategic areas, as it might have been soaking in a bit more in these areas.
The work time was good, meaning there was more than enough time to thoroughly spread the product, and insure evenness of product coating. As it went on it went on with a extremely high gloss, and the Trim, and Step Pads had a very nice dark restored look.
After I applied, and waited about 10-15 minutes, I touched the Trim in a couple of inconspicuous areas, and noted that not only was the product not dry, but was sticky, and was seemingly beginning to set up. As I did this, my fingers did leave small marks in the coating, and I did go back and lightly touch these areas up.
At that point, I was unsure how long a wait I was in for for the product to dry, and then was worried that it was never going to fully dry?
I left it alone for a period of about 1-1/2-2 hours time, and went to check again. The product still was showing a very nice high gloss, but at the point in time, I did not touch any of the Vinyl. At 2-1/2 hours, I checked by touch, and the product was totally dry. The gloss seemed a little less wet looking, but still very nice looking.
Now here's some bad news that I conclude at this point. Half the bottle is empty, so one could say it cost me $$32.50 to treat the Step Bumper Trim, and Rear Tailgate Handle. Absurd, I know.
I conclude that if I needed to coat all outside Vinyl Trim on my Tahoe, I'd probably be needing 2, to 2-1/2 Bottle of this product.
As for longevity, I of course cannot comment about such at this point?
As others have commented about such treatments, is it better to spend more, and have a product last longer, or spend less, and have a need to apply such a bit more frequently?
Pros: Seems to be a good product, I'm satisfied with the look, and ease of application.
Cons: An extremely expensive (IMO) product, seems to have a lengthy dry time (Might be temperature dependent), and becomes sticky as it dries.
Conclusions, and whether I would personally buy this product again? Probably not, it is prohibitively expensive for the amount of product, and I personally would most likely not consider this product again, unless maybe it was a 100ml Bottle of product, instead of the small 30ml.
The first pic shows part application of product. The others show the job complete.
Chrome was done with Optimum Opti-Seal.
Mark
Mark
