STI4Life06
- Nov 28, 2010
- 211
I am testing these two products and am running into a hazing issue. So I polished down my testing hood and used panel wipe to cleanup any polishing oils. I applied the CS Light which was fine and had no issues. I followed up with EXO about 20 minutes later and I am getting haze no matter how much I wipe with my clean MF. I thought maybe it was because I was wiping too soon at first so I waited a little longer for the coating to flash before I wiped but still same problem.
I then tried applying CS To the other side of hood but this time after applying CS I waited 2 hours before applying EXO and I am STILL getting haze. Can't tell if I am doing something wrong or what. It's about 79 degrees in my garage and I am keeping my dehumidifier to about 50% humidity.
Pictures show the issue I am having. Hood has clear coat failure (crows feet) but I don't think that's the issue here.
Any ideas?
p
Any ideas?
